Advice needed on my first e-bike
This Wreckage
This Wreckage
Cube says it's 27.9kg: https://www.cube.eu/uk-en/cube-supreme-hybrid-deluxe-one-600-indigoblue-n-switch/114400
Shrk says it's 28.5kg: https://www.sharkebikes.com/products/mako
Gazelle says 27kg, without the battery: https://www.gazellebikes.com/en-gb/ebikes/grenoble-c5-hmb
Are they making their bikes from wrought iron with concrete bearings because I don't understand how my 2021 bike can be so much lighter.
I'm not in any hurry to get rid of my excellent - if heavy at 19kg - pushbike which is a belt drive Gazelle Esprit. I think I'll wait awhile before making a leap onto the saddle of an e-bike, as I have insufficient space for two bikes.
CXRAndy
Lincs
Gazelle now do Esprit in ebike version now.
You need a new house then. Only one bike, that does not compute ! ^_^
I was going to ask, what is the bike made of weighing 19kg, then looked it up, ah a Dutch bike. I'll be brutally honest, dutch bikes aren't the nicest things to ride and are very heavy. Plus handling is 'interesting at best. I'd personally recommend looking at a modern ladies hybrid. My wife has an older Pinnacle Stratus 3, like attached. It handles well, is quick and light.
I had the delight of servicing a friends new Pashley, my word it was like a steam roller.
https://www.ebay.co.uk/itm/25671724...489&gbraid=0AAAAACnT8Vtf-EYyBAz-KTciuzGigJ0sj
CXRAndy
Lincs
I went with a male/unisex aluminum commuter bike as the donor for the wife's conversion.
I fitted suspension on the front with lockout and dropper post for her. She loves this feature, dropping the seat at junctions, so she can confidently place leg for stability.
Dadam
SW Leeds
Given your needs in the OP, I'd recommend either a relatively lightweight regular ebike, or an electric folder.
A non-folding bike needs lifting up. Your existing bike weighs 19kg so I'd suggest you need to consider no heavier than that. Sub 20kg usually implies a non-removable battery due to reasons I outlined up thread. It typically means a fairly small battery too. However that's not necessarily an issue as range extender batteries are an option on many bikes.
A folder removes the need to lift the bike onto the racks, and also increases flexibility for getting on the train. It's luggage so you don't have to book a bike slot or risk one not being available. Electric folders do come with other compromises of course.
I'd carefully consider whether belt drive is worth the other compromises. Nothing wrong with it as a drivetrain, but it does reduce options. For example the Tenways bike you mentioned is a single speed. Given your use case of a day's riding with a few light hills that may be fine, but potentially reduces the kind of gradients you can get up. If you want gears with a belt drive you need a hub gear which means a mid motor, and quite a bit more expense. Going for chain drive gives more choice of bikes with more gears, for the price of a teeny bit more maintenance (i.e occasional use of a rag and a bottle of oil).
This Wreckage
This Wreckage
Thanks for the advice. My five decades of experience with chain drive bikes drove me to abandon them for my Gazelle belt drive which, though heavy, is a marvel in every other way. I will not return to a chain bike; I would rather walk or take the bus and never cycle again. As things stand, my Gazelle is doing well for me so there is no tearing hurry for me to move to an e-bike yet. The more I investigate them, the less attractive they become with all their fuss and bother. But the replies here have been helpful and informative.
CXRAndy
Lincs
Chain drive has been around for 900 years if not longer
Its a simple, robust, cheap efficient drive system. There is very little to do in maintaining the chain drive.
Only downside is a chain tattoo now and then.
I have a Kalkoff Agattu ebike with belt drive, inherited from my dad in 2017. Apart from tensioning the belt once I’ve never had to touch it. And I’m a fan of hub gears (Alfine 8 in this case) so I guess I’m a lost cause!
CXRAndy
Lincs
My next ebike project is adding motor kit to Afline 11 Di2 Genesis touring bike. I'll be using a pannier rack battery mount
mjr
there's nothing about the Netherlands that makes Dutch bikes heavier. Some gazelles are pretty light. Of course, that's not what they hire out to clueless Brit tourists!
Handling is different to the typical leaning-forwards hybrid, more the old English roadster swooping steering, but not worse.
Back on topic, move that 25kg is the maximum for those train bike hooks on LNER
I'd probably get a folding bike if you can, to avoid the hooks and any future spreading of the London e-bike bans.
dicko
Derbyshire
I’m going to be 80 this year and am looking forward to buying possibly my last cycle. I do like the look of the Gazelle range of Dutch E bikes especially the ones with the belt drive. I discovered that CyclingMickey rides a Gazelle like the one I hope to acquire.
