Advice on Buying a Bike
NewBike
Hi there,
I'm thinking of buying this bike (see photos) but not sure if it's good... I'm not a very good cyclist but will need a comfortable, stable bike that will keep dirt off in bad weather. Also, what are some model related information I should be aware of before buying?
Many thanks!
biggs682
Northamptonshire
First of all go and take it for a ride to make sure you fit the bike .
Then check all the gears are selectable and the brakes work , check for any buckle's when spinning the wheels .
Where are you based? As there might be cc regular who would or could accompany you .
That should do to start with .
Cycleops
Accra, Ghana
Firstly hello and welcome. As a type the bike should fit your needs. You need to be aware this is a budget brand so will have cheaper components so will need checking over as Biggs says. If it's had little use you should be OK. For your comfort you need to have the right size. What is your height and inseam? When sitting on the saddle your leg should be straight with the pedal at six o'clock. The frame is a small size so I assume you are too.
If someone who knows about bikes could check it over that would be a great help. How much is the seller asking?
froze
It would be helpful if you give us a price range you can afford, because no sense in showing you a $4,000 bike if in your mind you only want to spend $400, or vice a versa.
