Aero/tri bars
montage
God Almighty
Bethlehem
£20 + postage of collect from near Fareham
A couple of notes :
  • these two bars used to be one solid bar, looped over - however I found this impractical and so separated the two sides using a hacksaw. I advise putting a bit of tape or bar end plugs into the end.
  • these don't usually come with grip tape - I applied some but you can easily remove it if wished
  • The arm pads are on a set of springs the spring the pad into a more vertical position when you are not leaning on them. I was told that the idea of this is so that you can use the tops whilst climbing.
  • The have not been used all that much, less than half a dozen TTs.
  • Fits OS bars.
    Any questions please ask
Norfolk
Interested but want pic
