Alex Moulton -> Gravel tourer
dimrub
Hi folks!
I'm thinking of getting myself a rescue Alex Moulton (either frame or a full bike) and converting it to a modern gravel tourer. Wide flaired dropbar, 2x11 groupset (maybe a 105), nice modern brakes (rim, no crazy adventures here), 45 mil gravel tires, a B17 to rest my bum upon, the works. Are you knowledgeable folks aware of anyone pulling something like this off successfully? Any advice? In particular, which model(s) to be on the lookout for? I think, an ABP Land Rover edition might be a good start, but it seems AM had quite a few models over the years, so maybe I can expand the search.
If you happen to know of a particular frame for sale, so much the better. I'll be in London through July, and I'll be willing to travel if the treasure is worth the trip.
Drago
No advice, but looking forward to seeing the finished article.
Ian H
Ancient randonneur
Check the OLN dimensions. I believe an older 1960's bike, using hub gears could be as little as 114mm.
Later models have much wider OLNs.
I wouldn't do it with a Moulton, but an AM of the space-frame variety might just about work.
dimrub
dimrub
I might have a donor bicycle, fingers crossed. I am afraid to jinx it, but on the other hand, I do want to share the excitement. It's a 2016 TSR27 in what appears to be immaculate condition, well taken care of. It's a way nicer bike than I was aiming at, but no harm in that. A bit pity about the very good parts I'm going to take off it, but maybe I'll be able to sell them, so the difference in price is not as large - and also, its paintjob appears to be in great condition, so one less worry. I will be able to reuse the stem and perhaps even the brakes, definitely the saddle.
All that is standing between it and me is getting on a plane then coming out to collect it.
dimrub
dimrub
The plan is coming together. Here's what it should look like eventually, give or take a few:
  1. Base: 2016 XTR in great condition.
  2. Wheelset: Silverock
  3. Drivetrain:
    1. Bottom Bracket: Shimano Hollowtech
    2. Crankset: 130BCD 170mm cranks alloy
    3. Chainring: NW 50T
    4. Cassette: Shimano SLX 11s 11-42T
  4. RD, brifters: SENSAH SRX
  5. Brakes: mini-V Shimano BR-R353
  6. Handlebar: 12 degree flare, 440mm
  7. Tires: Schwalbe Billy Bonkers 38mm. Later on, if I see there's enough clearence, I might go wider.
  8. Tubes: RideNow TPU
I'm leaving the Brooks saddle on, as well as the adjustable stem (for now at least). For touring, I'll get an original rear rack and an Alex Moulton touring bag. At 24L and waterproof, it's all I need to store my stuff (well, that, and the handlebar bag and two bottle cages).
On the other hand, a few things are coming off and will go on sale: the wheels, the RD (SRAM DD3), the handlerbar, the Ergon grips, the crankset. Maybe I can recoup a few pounds that way.
dimrub
dimrub
Be sure to install brake levers designed to work with linear-pull / V-brakes. Or fit a cable pull adaptor.
Yep, I've ordered mini-V brakes that are supposed to be compatible with STI levers. There seems to be a bit of a trade off there between brake modulation and pads closeness to the rim. We'll see.
