Alternative comfort bars and stem for a S-Works Roubaix 2014
PaulSB
My hands hurt after 10 mins on my S-Works Roubaix 2014 bike (with zertze inserts not future shock). When I bought it the bike came with a Zipp SL 90mm stem with -6 drop and Aerofly bars and while the bike itself feels lovely for the quite terrible roads around here, the entire cockpit positioning is just wrong for a more comfort oriented older rider like me.
They look great on the bike of course and I want something light weight and commensurate with the rest of the components but what are my options here?
I am very new to road cycling.
To my mind everything you have posted suggests your overall set up/bike position needs checking. I would start from scratch and make no assumptions. Don't make any purchases until you've done this and hopefully identified, correctly, what causes the discomfort. It does sound as though you have too much weight through the arms, this is very tiring.
I'm an older rider, 71, so I understand the comfort issue. If getting your bike fit correct doesn't solve the issue you probably have to accept this is the wrong bike for you. I don't know the bike but have read it's designed for endurance, comfort and pace. A difficult combination, I didn't realise it was intended to do this, it's never been my impression of the bikes I've seen being ridden. The only brand I've come across that genuinely delivers on this promise, for my needs, is Cervelo.
8mph
Devon
Providing there's some steerer tube showing and room to adjust stem hight with spacers, something like this might help. Also, as others have already said, check that the saddle is level. Double wrapping the bars may help.
I bought the above stem for extra comfort on tour. Obviously, select the appropriate clamp diameter for your bars.
You can see the effect of the rise here
B
bulldoze
I bought a Royal Alpine 80mm 6deg stem in the end and flipped it so it is +6. I also twisted the aero bars upwards to what I guess is a not very aero angle.
More comfortable for sure. Not sure it is perfect yet though - more rides required.
