Holdsworth
- Crewe, Cheshire
My first argument with a driver of any kind for ages. This was on my commute back from work, end of my 2nd week in my new job on the industrial estate.
I was cycling down Macon Way in Crewe towards Hungerford Road when I stopped at these lights, which had gone red and someone was crossing on a cycle. I set off and stayed on the road as I tend not to use the cycle path on the pavement as I much prefer the road. There are very few shared use paths that I will use and this isn't one of them.
Anyway I set off on the green light and 100 yards later get a close pass by a silver car (no memory of the make/model or number plate, need to get the camera operational again!), it wasn't particularly bad and I was going to let is pass if it wasn't for obvious hand signals pointing to the path through the back window by the driver. My Airzound was nearly depleted at the time so that let out a little parp to little effect.
I eventually catch him up at the inevitable queue a few hundred yards later before the roundabout and ask him about the hand signals. Dialogue as follows:
Me: "why the hand signal?"
Driver: "what hand signals?"
Me: "the pointing you were giving through the back window"
Driver: "I was shouting at you yer prick!" (I didn't hear anything as he passed so I didn't realise he had done that as well)
Me: (I was p****d off at that remark, was going to reason with him but now...) "**** off!"
Driver: (Starts to open driver-side door)
Me: (Sensing danger I cycle off into the distance and leave him behind)
I suppose I could/should've handled it better but his attitude made me forget all of what I was meant to do in that sort of situation.
If/when it happens again I will try to keep calm, maybe even avoid confrontation altogether, so something like that doesn't happen again. I must take some form of anger management class as it takes relatively little verbal provocation for me to retort like I did today; and, as it showed in this instance, it just leads to a bad outcome and could've ended badly!
