Another Hanger Question
Hi,
I removed the rear mech hanger from one of my bikes tonight as shifting was a bit hit and miss. When I lay it on the work bench it wasn't lying perfectly flat on the surface but slightly of by a few mm on one side ie wobbles a bit.
Forgive if this seems silly but is that evidence of a bent hanger or can that be found in some types of hanger. Should a hanger lie perfectly flat on a flat surface The mech is a Kinesis.
Cheers for ideas. :idea:
Loch side.
Bang it flat. Don't try and bend it in the vice. Aluminium work hardens when bent and if you try and use something like a vice and a shifting spanner to bend it, the new bend will be next to the old one rather than over it, leaving you with an S shape. Hit it with a hammer until it listens.
Thanks for the advice yellow saddle. Is it safe to assume that it's bent.
S.Giles
When I bought a brand-new hanger for my bike, I had to bend it slightly so that the derailleur was hanging vertically. The hanger as supplied (ie, perfectly flat) didn't work properly. So, look at the derailleur, not the hanger. If the derailleur is hanging vertically down (when viewed from behind), leave the hanger alone.
screenman
Slightly wrong advice there, as it can be wrong in other angles, you should check overall alignment, preferably by using the correct tools.
Loch side.
When fitted to the bike a hanger can be aligned correctly to the frame and the wheel.(using a hanger alignment tool)
Banging it in a vice or with a hammer cannot set it up properly no matter how hard you hit it.
It seems you've never tried. Getting a piece of aluminium or even steel flat by banging it with a hammer is pretty easy. Just because replacement is even easier, it doesn't mean you can't resort to old fashioned methods. Obviously this should be done on a flat surface off the bike, but then the OP understands that, having already taken it off and put it on a flat surface to see whether it is flat or not.
I have explained why a vice doesn't work (other than to perhaps provide a convenient flat surface by way of little in-built anvil.
Next time you bend a removable hanger, give it a try, you'll be surprised.
Loch side.
Common sense should tell you whether it is bent or not.
Aluminium hangers are generally anodized. This is the shiny, protective layer on top of the raw aluminium and is usually black or silver. However, it can be any colour. Anodising is a hard layer of ceramic that lies on the surface - one half submerged in the aluminium, one half on top. It is completely unlike a coating of paint or electroplating in that way. This provides us with a convenient indicator whether the piece is bent or not. If you look at the suspected bended area you'll notice fine hairline cracks. Because anodizing is so hard, it doesn't bend with the aluminium but cracks in this way. These little cracks are called crazing.
Have a look or post a photo. It is important for a good diagnosis though, to be sure that it is anodized but I'll be surprised if it isn't.
I hate the bloody American spell checker on this forum that changes all my English words into American. There is no Z in anodize.
raleighnut
No I don't suppose that after working in Foundries and Forges for ten years that I have much experience with metalwork so it's a good job that I went to college and did my Cabinetmakers City & Guilds.
Still it could be worse, I could still be a Motor Mechanic (my choice of career as a callow youth in the 70s)
Loch side.
Rather than flaunt your career as a box maker and car fixer, why not just tackle the issue at hand and tell us why you cannot flatten a piece of aluminium on an anvil. Surely that will contribute to the understanding of the problem at hand more than a CV?
Loch side.
To the OP: @wam68 . I wont be surprised if you are confused after having been presented with two sets of conflicting advice. I hope by clarifying my stance you'll be able to make a better decision regarding your possibly bent derailer hanger.
Modern derailer hangers are designed as sacrificial parts to protect both the frame and derailer from damage when a bike falls over or crashes. The hanger is designed to bend. Older steel frames had an integral hanger that was part of the cast-iron lug that connected the seat-stay, chain-stay and drop-out. It did bend readily because it was designed rather slender, but obviously once it is broken, repair is expensive. Nowadays we simply buy a new hanger and bolt it on. It is practically a consumable and hard-core MTB stage racers carry a spare one around their neck on a leather thong where it serves as a bit of jewellery that can come in handy in the event of a crash. In the field it is much easier to replace the hanger using a single allen key rather than to attempt to bend it straight. In the workshop you have options and time. There are even special tools for straightening derailer hangers such as this one from Park (rather clunky) or this beauty from Shimano. I am biased on this one.
Both these tools are designed to perform slight corrections of a bent derailer hanger whilst on the bike. This goes for permanent or sacrificial hangers.
There is a problem with these tools though and that stems from the nature of certain metals to work harden. You can read about it here.
This is quite a big problem for bicycle mechanics, especially if they don't know what to look for.
Here's a picture of a typical hanger. At the top are the two mounting holes for bolts to attach the hanger to the frame. The frame has a correspondingly mated surface to match the odd-shaped recess in the hanger. The bolts only hold the hanger at the top and if it is perfectly flat, it pulls the hanger against the frame and you have a reasonable joint. I say reasonable because it is just good enough to not flex when shifting but as you can see, if you apply a force the bottom part, it will flex and then bend. It is designed to be like that so that it won't damage the frame. However, when straightening it, the bend, typically in a straight line just above the bottom thick part of the hanger, doesn't go back to its original shape because that zone is now harder than the zones adjacent to it which are still soft. The new bend will now be in one of these zones and this means that although technically straight (the derailer is in line with the sprocket plane again), it is now unstable because it is no longer lying flat against the frame. If you look at it from the back you can often see it's new S-shape and a gap between the hanger and the frame. The derailer will now flex easily because of this poor link. Shifting is compromised.
No matter how fancy the tool (and the Shimano one is fancy), it cannot do the job properly and a straightened hanger is a problem hanger. The solution is to remove it, lay it on an anvil and hammer it flat. One or two well-aimed blows does the job and you can confirm the effect by aiming it against a straight edge. Then you refit it and use the tool to confirm that it is indeed in line. The tool will make small corrections too because you now work from a good base. If you don't have the tool, you'll have to confirm that it is good by getting good adjustment from the derailer.
Work hardening is poorly understood by most bike mechanics because it is not part of any curriculum I've seen. A beautiful example of work hardening at work can be seen on damaged aluminium freehub bodies. These get gauged by steel sprockets cutting into them from pedaling forces. However, the sprocket doesn't cut deeper and deeper but arrests the process by itself. This is because the aluminium becomes progressively harder as the cut progresses.
Side view of freehub body damage.
Aluminium hangers, including the one in the photo above, are anodized. This is the shiny, protective layer on top of the raw aluminium and is usually black or silver. However, it can be any colour. Anodising is a hard layer of ceramic that lies on the surface - one half submerged in the aluminium, one half on top. It is completely unlike a coating of paint or electroplating in that way. This provides us with a convenient indicator whether the piece is bent or not. If you look at the suspected bended area you'll notice fine hairline cracks. Because anodizing is so hard, it doesn't bend with the aluminium but cracks in this way. These little cracks are called crazing and are great for showing you exactly where the bent zone (and now hard zone) is l located.
One more thing. In an accident a hanger usually bends inwards because that's the way the bike falls. If you now put your wobbly hanger on a flat surface and keep track of its orientation on the bike, it should be evident that the bend is in the right direction, giving you just a bit more confidence that it is indeed bent. If the bend is in the opposite direction, be suspicious unless of course you know the cause and it all adds up.
@wam68 I hope this gives you a better understanding of hanger repair.
raleighnut
Work hardening is poorly understood by most bike mechanics because it is not part of any curriculum I've seen. A beautiful example of work hardening at work can be seen on damaged aluminium freehub bodies. These get gauged by steel sprockets cutting into them from pedaling forces. However, the sprocket doesn't cut deeper and deeper but arrests the process by itself. This is because the aluminium becomes progressively harder as the cut progresses. View attachment 83787
Please note that anodising is very similar to electroplating in that in plating there is an Anode and a Cathode, the difference being that with deposit plating metal is transferred to the Cathode, whereas Anodising is the reverse and leaves a coating of Aluminium Oxide Al2 O3 or Corundum on the surface, certainly not ceramic.........................Google it.
