Sheffield_Tiger
Bloody "scrapmen" had away with my Mule trailer - god knows why, thin steel tube frame, plastic joints, mostly canvas and wood base.
Replaced with this:
http://www.amazon.co.uk/dp/B007D34WHO/ref=pe_217191_31005151_3p_dp_1
Seems well built. okay for the price it does rely a little on nylock nuts and plastic bushings but the over-engineer in me will probably pick up some slightly longer bolts and double-nut the folding joints. Hub rolls rough, cheap pressed steel hub with push in bearing faces...but will probably rebuild onto another hub at some point. Coupling seems good - no chance of using with my Pylon with nexus gears but will suit my regular commuter and the Catrike with no issues.
And being single wheel it doesn't tip over like the mule. Not as big load space though. Rolls well and not as bad into a headwind as the slab fronted Mule was
Replaced with this:
