Any info on this bike?
SpaceSputnik
Member
Toronto, ON
Hi All
I had this bike for a long time but never really bothered to learn more about it.
I bought it used on in 2001. It was really beat up. I fixed it up and upgraded some parts and rode it for a bit on hardpack rail trals around Toronto. It really never let me down and was always quite enjoyable.
So. From what I can read on the frame its a Norco. Not much else can be seen due to the frame stickers being largely ripped off. The frame seems aluminum since the bike is quite light compared to big box store bargains. It has. Overall it is old but seems quite decent. Gears shift reliably and no mechanical issues to speak off.
Googling didn't bear any fruit so far.
I guess any info would be nice to have.
Norco are an American brand. This is mainly a UK forum, although the brand is available here only more recently, and only at one shop so quite uncommon
Thus, you might have more joy on a North American forum of none here
Photos of the whole bike would be useful too :okay:
SpaceSputnik
SpaceSputnik
Member
Toronto, ON
^ thanks, didn't realize it was mostly UK.
I thought I attached more pics. Let's try again.
deptfordmarmoset
Full time tea drinker
Armonmy Way
I believe that they're actually Canadian, based in BC. So the far side of the Rockies from the OP.
EDIT: Oops, too late! But there's a Norco archive page here: https://www.norco.com/bike-archives/2011/
Tim Hall
Crawley
Easy check to confirm it's steel.or not is to see if a magnet is attracted. While you're trying to find the instructions for the computer, use the magnet off the front wheel.
classic33
Leg End Member
Does this match?
Frame & Fork
Frame Construction TIG-welded
Frame Material Chromoly
Fork Norco
Fork Materal Chromoly, unicrown crown
Rear Shock Not applicable
Components
Component Group Mountain Mix
Brakeset Chang Star linear-pull brakes, Chang Star linear-pull levers
Shift Levers Shimano Revo
Front Derailleur Shimano Tourney TY-32, top-pull
Rear Derailleur Shimano Tourney TY-30
Crankset Shimano Tourney TY-30, 28/38/48 teeth
Pedals Victor VP-896
Bottom Bracket Three piece, sealed
BB Shell Width Unspecified
Rear Cogs 7-speed, 14 - 28 teeth
Chain KMC Z-51, 1/2 x 1/8"
Seatpost Aluminum micro-adjust
Saddle Velo VL-2004
Handlebar Extensions Not included
Handlebars Steel, rise
Handlebar Stem Steel
Headset 1 1/8" threadless YST
Wheels
Wheel Size 26" wheels
Hubs Front: Joy Tech aluminum, Q/R, Rear: Joy Tech aluminum, nutted
Rims Alex Y-2000, 36-hole
Front Tire 26 x 2.10" multi-terrain
Rear Tire Not Available
Spoke Brand UCP, 2.0mm straight gauge
Spoke Nipples Unspecified
Scotchland
Looks a bit like a Norco Citadel with a strange paint job.
But the more you look at it - the stem is much more modern, but you did a bit of work on it you said.
Those bikes are heavy, but comfy tanks.
They looked like this in 2005, but I thin there was another colour, or a very similar model the year before.
SpaceSputnik
SpaceSputnik
Member
Toronto, ON
Holy molly guys, thanks!
What I can verify does match.
I did replace...can't even remember now. Derailer maybe or cogs. Front wheel for sure. Rear may be from a crap SuperCycle I had before.
SpaceSputnik
SpaceSputnik
Member
Toronto, ON
I did not touch the stem. It is exactly the way it was 17 years ago when I got it.
