swee'pea99
The extractor in our downstairs loo has stopped extracting. It just groans gently to itself. If I look up into the gizzards I can see fan blades revolving, at about 1rpm. I'd like to get it out and have a play around, and if necessary replace it. But I can't see how to actually remove the thing. Or, in the first instance, remove the top plate to let me have a proper look at the innards.
It's all very neat & sealed...
You can lift the edges of the top plate a mm or two by fingernail, all the way round equally, but it seems firmly gripped in the middle. At first I assumed a screw under that central 'bud'
...so I tried tweaking it with the tip of a Stanley knife. But nope, it certainly doesn't feel happy to pop off. Then I saw that little white screw head on the left, so for want of any other obvious options I had a few tweaks with that - made no difference. Didn't think it would.
Ok, so plan B - remove the whole unit. Now, I didn't fit it, and the main unit is pretty inaccessible, but I did manage to get my phone up into the recess enough to get this:
Some kind of spring-loaded nylon thingy. Now, I can't get my hand round the other side to feel whether there's one on t'other side too (my guess would be yes), but my efforts to raise the unit a little so's to be able to squeeze the clips closed so's to release the unit have been pathetically ineffective. That clip thingy is strong, and it's going nowhere. I guess if push comes to shove I can always go the other way and try to break the clip thingy, but I was wondering if anyone might recognise the unit and come up with the ideal - and probably obvious, except to me - solution.
Any suggestions/advice/ hints 'n tips much appreciated.
