Anyone use CO2 'pumps'?
parklaneyido
I'm considering investing in a co2 pump thingymabob. Anyone use them? Would you recommend them over a hand pump becuase frankly, pumping to 100psi with my topeak mini bullet is impossible
parklaneyido
parklaneyido
Fiona N
I use a CO2 thingy which also functions as a pump. It allows partial use of a CO2 cylinder too so you can just top up tyres rather than just inflating from scratch. Like you, I find getting 100+ psi out of a mini pump too difficult (although I have a mini track pump which is OK-ish) so being able to partially inflate an inner tube and put a bit of air into the tyres with the pump followed by full inflation with the OC2 is a nice combination. I don't have many ****s so the expense and environmental impact of dozens of little cylinders doesn't come up. And I use a great track pump at home, of course ;)
Noodley
I carry CO2 pump, great wee thing. Quick, efficient and saves energy. No point knackering yourself even more trying to pump up a tyre to 100psi?
Noodley
Very easy. Screw the canister onto the valve, screw the valve onto the nipple and release the gas by turning the wheel on the valve. I never screw the cannister onto the valve before I need it, as it might get a knock and accidentally expel the gas :sad:
parklaneyido
parklaneyido
Nice one!!
Noodley
montage said:
I am with Noodley on this one, not sure what PSI they get the tyre to though - need to check that!
Click on the images of the cylinders and it gives PSI values. 16g gives upto 130psi for road tyres.
I always deflate tyres when I get home and re-inflate using track pump - I can't remember why but I had read something ages ago and have always done this since. There is a limit to how much my small brain can retain....;)
montage
God Almighty
Bethlehem
Something to do with it being CO2 rather than air I guess....but I can't think what.
On a gas related subject - why don't TdF riders fill their bikes with helium? ;) :tongue:
palinurus
Velo, boulot, dodo
Watford
It's probably because carbon dioxide, although a bigger molecule than nitrogen, diffuses at a faster rate through butyl rubber. So it makes sense reinflate with air since you'd have to do it soon enough anyway.
