Anything to be aware of when switching to a compact?
Cyclopathic
Leicester.
I'm currently running a 53/42 chainring on a ten year old Shimano 105 gear set with a 9 speed block and sti's. Is life so kind that I can simply change the chainring to a 50/36 compact and off I go or will I have to replace the rear mech for one with a longer cage? Also do I have to get a specific 9 speed compatible compact? Finaly are ther any issues with the front mech or will it handle the change? Absolutely finaly is are there any other pitfalls to look out for that I have not identified?
Thanks folks.
mattobrien
Sunny Suffolk
If the rear mech will allow, you might find that you could gt the desired change in gearing by swapping the cassette, although you don't mention what cassette range you are running. Every chance this might be a less problematic route.
Cyclopathic
Cyclopathic
Leicester.
Sorry, my fault. I meant the chainset. I want to change the entire chainset from the 53/42 to the compact 50/36, not just the chainring. I'm just wondering what other issues there might be as listed in my op. Apologies for my schoolboy error.:blush:
Andrew_P
In between here and there
I would have thought a Short Cage would be fine, you might have to run a shorter chain. Only making this observation as you are decreasing the front only?
Cyclopathic
Cyclopathic
Leicester.
Sweet. That's the kind of news I want to hear. I'll ask you again when I need to know something.:smile:
boydj
Paisley
You'll have to adjust the height of your front mech. Hopefully it should cope with the bigger difference between chainrings.
Cyclopathic
Cyclopathic
Leicester.
That's fine. I was envisaging having to change everything which would have completely defeated the object of putting this particular bike together because I've got a complete 105 group set on a bike that I want to put on a different frame with the exception of the unnecessarily (for me) large 53/42 chainset.
