Are you Flying Safely ???
After every flight, pilots fill out a form called a gripe sheet, which conveys to the mechanics problems encountered with the aircraft during the flight that need repair or correction. The mechanics read and correct the problem, and then respond in writing on the lower half of the form what remedial action was taken, and the pilot reviews the gripe sheets before the next flight.
Never let it be said that ground crews and engineers lack a sense of humour. Here are some actual logged maintenance complaints and problems as submitted by Qantas pilots and the solution recorded by maintenance engineers. Qantas is the only major airline that has never had an accident.
(P = The problem logged by the pilot.) (S = The solution and action taken by the engineers.)
P: Left inside main tyre almost needs replacement.
S: Almost replaced left inside main tyre.
P: Test flight OK, except auto-land very rough.
S: Auto-land not installed on this aircraft.
P: Something loose in cockpit.
S: Something tightened in cockpit.
P: Dead bugs on windshield.
S: Live bugs on back-order.
P: Autopilot in altitude-hold mode produces a 200 feet per minute descent.
S: Cannot reproduce problem on ground.
P: Evidence of leak on right main landing gear.
S: Evidence removed.
P: DME volume unbelievably loud.
S: DME volume set to more believable level.
P: Friction locks cause throttle levers to stick.
S: That's what they're there for.
P: IFF inoperative.
S: IFF always inoperative in OFF mode.
P: Suspected crack in windshield.
S: Suspect you're right.
P: Number 3 engine missing.
S: Engine found on right wing after brief search.
P: Aircraft handles funny.
S: Aircraft warned to straighten up, fly right, and be serious.
P: Target radar hums.
S: Reprogrammed target radar with lyrics.
P: Mouse in cockpit.
S: Cat installed.
P: Noise coming from under instrument panel. Sounds like a midget pounding on something with a hammer.
S: Took hammer away from midget.
Rhythm Thief
Ross on Wye
Seen it before, but always worth another read. I especially like "something loose in cockpit".:smile:
bauldbairn
Falkirk
:smile::rofl::smile::rofl::rofl::rofl::rofl:
Well done! That's the funniest thing I've read on here in ages.
That appeals to my sense of humour!
Aircraft engineers are generally very good. With all the responsibilities they have - can't fault them for having a sense of humour too! :thumbsup:
Bay Runner
Bay Runner
If you did fault them they would only write about you :smile:
Bay Runner
Bay Runner
bauldbairn said:
So who landed the plane - if the pilot "thought" it was on auto land? :rofl: - :smile:
Must have been this guy :smile:
As the test pilot climbs out of the experimental aircraft,
having torn off the wings and tail in the crash landing,
the crash truck arrives; the rescuer sees a bloodied pilot and asks,
'What happened?'
The pilot's reply:
'I don't know, I just got here myself!'
Attributed to Ray Crandell(Lockheed test pilot)
ianrauk
Tattooed Beat Messiah
Rides Ti2
Very old but very funny. It reminds me of another old one
USS Warship v A Lighthouse
“Again this is the USS Montana requesting that you immediately divert your course 15 degrees to the North to avoid a collision. Over.”
“Please divert your course 15 degrees to the south to avoid collision.”
The American end of the conversation is now taken over by the ship’s captain.
“This is Captain Hancock. You will divert your course. Over.”
“Negative captain. I’m not moving anything. Change your course. Over.”
“Son. This is the USS Montana, the second largest vessel in the North Atlantic Fleet. You WILL change course fifteen degrees North or I will be forced to take measures to ensure the safety of this ship. Over!”
“This is a lighthouse. It’s your call… Hello… Captain?”
bauldbairn
Falkirk
Not seen that one for a while - top class! ;):laugh::becool:
Whats the difference between an aircraft and a pilot?
The aircraft stops whining when it lands and the engine is switched off.
