Automatic gear shifter?
presta
Yes there have been some made, but they've not caught on. I recall reading about one, and the reviewer saying it felt pretty weird to ride.
Optimum cadence depends on you power output, which depends on gradient as well as speed, so it would just be a PITA, and rarely optimum.
PaulSB
Is there a system that automatically shifts gear up or down depending on your speed or pressure on pedals or somesuch?
I've never heard of one but imagine someone, somewhere will have dreamt it up.
One only has to ride di2 with the "auto" setting, I don't know its name, to understand this can never work. Shimano in their wisdom introduced a di2 setting which shifts the rear derailleur when the rider shifts the front. It's dreadful.
Gear selection on a bike is about the rider's feel and intuition. No automatic system could better that.
ColinJ
Puzzle game procrastinator!
A manual 1x setup is a good compromise.
When I ride my 1x bike in Devon it is almost like having automatic gears because I never think about gear shifts, they just get done.
Back on my 2x and 3x bikes, I sometimes hear a funny noise from the chain and then realise that I am crosschaining because I forgot to shift chainrings when I should have done.
Webbo2
I thought the auto setting was more a case if you were getting towards small and small it would change to the big ring and the appropriate rear sprocket and like wise when getting towards big and big.
I tried it on the turbo in shop when getting my new bike and I didn’t go for it because it felt like someone was changing gear for me.
cyberknight
and also your preferred cadence too , some spin and some like to push bigger gears .
markemark
My old car was very expensive and had automatic gears. I hated it. Was always in the wrong gear. Was a horrible delay whilst it was working out what I was trying to do. It was always reactive rather than proactive.
The only time it was vaguely useful is slow moving tedious stop-start traffic.
I wouldn’t want to replicate that on a bike.
Drago
The Urban Fringe
Aye, on a car you need a beefy engine to make a mechanical auto box work proper. Anything 4 cylinder, or below 2.5ish litre is usually horrid.
Electronic automated manual boxes are a different kettle of aquatic wildlife. Sensors, battery, actuators, can be made to work very well on dwrs but that's a lot of hardware and cash to translate it to a bicycle that virtually no one will buy anyway.
Alex321
South Wales
You think it is dreadful. Every review I have seen thinks the opposite.
And while I haven't yet tried a bike with Di2, I can only imagine it being of benefit, since I do what it does almost every time I change rings. The change between rings is always much bigger than the change between two sprockets, so you almost always want to change both together, in the same direction (opposite effect).
And you can always turn it off if you don't like it.
Tigerbiten
If you go for a hub gear setup then there's the Enviolo CVT hub. Enviolo Automatic is a “set and forget” system that adjusts to you – set your preferred pace and you’re ready to go. Simply set your desired cadence once (how many pedal rotations feel comfortable for you) and the Enviolo Hub will constantly adjust its internal gear ratio to maintain a steady smooth cadence regardless of the speed or riding conditions that you encounter. If you ride uphill it will adjust to a lower gear ratio for you and if you ride downhill it will do the opposite.
TheDoctor
The TerrorVortex
It's something that gets reinvented every so often, like oval chainrings, L-shaped cranks and indicator / brake light systems.
Like all of the above, it then sinks without trace, because it's a terrible idea.
The latest iteration I can find was this from 2016, but it's like the Deal Drive from the mid-80s.
Webbo2
I wonder how many posting have used Di2 on a regular basis. The wonderful Mrs W suggested I bought a new bike which I did and it came with Ultegra Di2. My other bike has Dura Ace mechanical which is great however Di2 is so fast and no adjusting of the front mech. I find I change gear far more often because you barely have move a finger. Generally I find I change with my little finger although as I have satellite buttons on the top of my brake hoods which require my thumbs.
Yes no one needs electric gears but nice thing to have.
Dadam
SW Leeds
I came to post the car comparison from the opposite perspective. I always hated automatic gears until I tried the 8 speed ZF box in my BMW. So creamy smooth that I often forget that there are gears changing. So much more relaxing to drive.
So while I've never ridden a Di2 bike and I'm perfectly happy with mechanical gears on a bike, I'm open minded to the possibility it might work well. I'd heard of the aforementioned Enviolo CVT as a colleague got an e-cargo bike on the C2W scheme.
Webbo2
We too have an automatic volvo, you can’t get them as a manual any more. I find so simple to drive as all you have to do is steer and brake.
cyberknight
Only had an automatic after over 30 years of stick shift and it's so easy to drive ,as it's a hybrid the trick is getting the EV part to kick in, I can get close to 70 mpg if I have to drive to work.
