Basic car battery charger
DRM
West Yorks
Even half a mile could be costly. Without water circulating, you'll blow a head gasket quicker than you think.
This with the caveat that it's just an alternator belt, and the water pump is driven by another belt, however the O.P has confirmed it was overheating getting back home
Jenkins
Jenkins
Felixstowe
I guess I'll find out if any head gasket problems are found as part of the MOT/service/belt replacement. I had no option as there was no way I was parking in a layby on that road (a good choice as it turned out due to the problems I had with the RAC).
CXRAndy
Lincs
Some smart chargers will not start to rejuvenate a fully depleted battery. You need a charger with restore feature. Or use a traditional transformer charger to lift the voltage sufficiently a smart charger will take over.
I only buy Ctek chargers for keeping vehicles batteries in good order. I do have DC power supplies to use in severely depleted lithium batteries
Loch side.
Head gasket problems usually leave you by the roadside. Its not something they find at MOT.
If you are with RAC they will usually transport to a garage after initial recovery depending upon your level of cover. No water pump also... big risk.
gbb
Peterborough
Am I really old fashioned to simply own a proper good old fashioned trickle charger :smile:
Crikey, I've had it 30 years in all probability, still works, only gets used once every 5 years or so, usually because a battery came to the end of ots life or a light was inadvertently left on.
Do we overthink things and over complicate it all ?
The above prompted me to actually fact check my assumption...and yes...modern batteries (EFB on mine) do require a smart charger. So perhaps I'll bin my old one and invest...except I just fitted a new battery so dont envisage problems...ah, maybe in the future...
presta
Mine's the one my father bought when he got his first car in 1965, but it hasn't been used in donkey's years. ^_^
T4tomo
Ask the garage whether your car's water pump is driven by the auxiliary drive belt (which has snapped) or the Cam belt and what their view is on driving it 1/2 a mile.
Those Noco charger / jump starters are an excellent bit of kit and worth investing in regardless.
They are. My son hadn't moved his track car for months. Plugged in my Noco and must have cranked it over 6 times before the car spluttered to life. Battery was quite flat by then but did its job.
Jenkins
Jenkins
Felixstowe
Just a quick update - I went for the Halfords 4A one at £27 as it's cheaper than an RAC callout for them to move the car. Put the battery on charge for a bit over three hours this morning and it's gone from not even clicking the starter motor to allowing the car to start & run. I only ran it for a few seconds just to make sure before switching everything off, so it looks like once I give it a full charge next week I'll be able to get the car to the garage under its own power.
I'll still be having a new battery fitted as the one on the car at the moment is the original 11 year old one and has been struggling for the past year or two.
I have a feeling my brother has done a bit of damage to his sump on his Kuga having it overheat a bit recently and carry on driving until the car told him to bugger off. He popped round this weekend, and I could see oil was seeping from around the gaskets for the plastic sump and the sump plug - I no doubt running a boiled engine won't have helped.
Alex321
South Wales
Do you have a friend who could give you a tow to the garage?
