Broadside
- Fleet, Hants
The bottom bracket on my wife's Specialized Dolce road bike has developed some play. I have removed it from the frame and it is a square taper marked as FSA 7420 (68 shell) and 116mm spindle.
I can find a replacement RPM branded unit but have read that these are not particularly good quality. I have also found the Shimano UN55 but can only find it with 115mm spindle length. I know it's only 1mm different, do you reckon this will be ok? They also do a 113mm spindle UN55 which is a tiny difference to the 115mm model, which makes me worry that the 1mm could be a big deal...
http://www.chainreactioncycles.com/shimano-un55-square-taper-bottom-bracket/rp-prod71369
