[QUOTE 4730723, member: 45"]Thanks. We had the same in the corner bedroom of the last house. We're on the side of a hill so I suspect any wind just increases the temperature differential on the wall.
I'm trying to get him to leave his window open at night but 15-year-olds don't seem to be as resilient as they used to be.
We've got one of those moisture traps and as it happens I have a shelf ready to fix. I'll put that up later and see how we get on.[/QUOTE]
No, don't do that unless you really want a shelf up there. Moisture traps (aka silica gel or "crystal cat litter" absorbs moisture from the air, but placing it next to the point of condensation won't help. It is the whole room's humidity that has to drop. You can't just de-humidify one spot. That's like thinking you can have a cold spot in the bath - it will mix in. Further, the condensation in one area simply shows you that the temperature of that spot is below the dew point, not that that spot is moist.
Cat litter is a cheap dehumidifier but you'll have to buy tons of the stuff to de-humidify the entire house. At best you can close that bedroom's door and attempt to isolate the one room. For that reason it works well in a sealed car. Unfortunately cat litter doesn't have the pink indicator Marky mentions. You'll never know when it is saturated or not, so you'll have to keep on drying it out every week or so.
Insulation and outside circulation are the only two real solutions.
