Best budget road bike
Ruth70
Hi all,
I am considering selling my touring bike and buying road bike instead. My budget around 400-500 GBP. What wuld be the best bike around this budget? Could be second hand too. I would like to be able to install a 28mm wheels on it. One of the models I have my eye on is Cube Axial, but interested to hear your opinions too.
Thanks!
Hi all,
Thanks!
Decathlon's Triban 520, would be my choice. A lot of bike for 450 quid. 28mm tyres fit with no problems, 9 speed Sora, and a very nice frame.
+1 on the Triban 520. I had a go on a friend's one and was most impressed with it.
It's good for 100 mile Sportives as well
Giant avail worth a look, definitely take 25mm tyres, not sure on 28s especially if wanting mudguards to fit
Decathlon don't offer a wsd range of roadbikes, so keep some budget for changes like a new saddle, potentially narrower bars etc
@Ruth70 are you confident buying online? If so, you could add Ashcycles and Paulscycles to that list of online retailers
Where are you based?
The best bike is one that fits you, is comfortable to ride and makes you smile while doing so :smile:
Dirk
If 6 Was 9
Watchet
I've put 28mm tyres and mudguards on my Giant Defy 5 - no problem.
Shouldn't be any different with a low spec Avail.
Dirk
If 6 Was 9
Watchet
I'm using the standard 'Giant' road mudguards and 28 mm Schwalbe look alike tyres (IMPAC - which I'm informed is Schwalbe's budget brand). No problem with clearance.
Karlt
B'Twin are great bikes and if anything goes wrong Decathlon will jump through hoops to get it sorted for you.
This is extremely true. I bought a Sport 1 in 2010, shortly before it was retired in favour of the Triban 3. After about six months I bent it in an underpass and because they couldn't get the original steel fork any more they sold me a Triban 3 Carbon Fork at cost - £50.
Then last August (2014) I needed to replace the bottle cage and found that the fixing bolts had seized to the mounting holes so that the bolt and hole just rotated around in the frame loosely without unscrewing. Because they couldn't get a replacement frame - this is four years on - they replaced the entire bike with a Triban 500 SE.
I can't fault that. I don't know how they make money, but they will honour warranties.
