Wilsy27
Hi,
I'm considering (....well, am definately going to) upgrading my current bike (Dahon Martix full size folder) to a road bike via the C2W scheme. Usual rules, can spend up to £1000.
My commute is 35 miles round trip from gatwick to croydon and back in the evening.
I'm thinking of going for the best bike frame I can get with the money and then upgrading the components as and when I have the funds as I go along (obviously needs to have some components on there to start with!!
My LBS has a Mekk P2.0 which looks smart - don't know if it can take a pannier or not (maybe a seat post one?) yep, I'm a noob to road bikes so any hints/suggestions great-full. I want to go via my LBS so that rules out Boardman and Ribble.(I believe at least?) but do want to go with an idea of what I'm looking for. In terms of size, I filled out the competitive cyclist form (to the amusement of my "helper"/girlfriend... she did giggle when I was holding a tube under my crotch with her holding a tape measure!! lol (see below for the measurements)
Below are the measurements you entered, followed by our calculations for proper frame size and component positioning. You can refer to these numbers when choosing your frame and component package on-line, and you can keep them handy if you'd like to place an order over the phone.
Measurements
Inseam: 81.00
Trunk: 60.25
Forearm: 36.00
Arm: 65.00
Thigh: 55.00
Lower Leg: 55.00
Sternal Notch: 146.00
Total Body Height: 175
The Competitive Fit (cm)
Seat tube range c-c: 52.4 - 52.9
Seat tube range c-t: 54.1 - 54.6
Top tube length: 55.8 - 56.2
Stem Length: 11.2 - 11.8
BB-Saddle Position: 79.3 - 81.3
Saddle-Handlebar: 52.4 - 53.0
Saddle Setback: 2.1 - 2.5
The Eddy Fit (cm)
Seat tube range c-c: 53.6 - 54.1
Seat tube range c-t: 55.3 - 55.8
Stem Length: 10.1 - 10.7
BB-Saddle Position: 78.5 - 80.5
Saddle-Handlebar: 53.2 - 53.8
Saddle Setback: 3.3 - 3.7
The French Fit (cm)
Seat tube range c-c: 55.3 - 55.8
Seat tube range c-t: 57.0 - 57.5
Top tube length: 57.0 - 57.4
Stem Length: 10.3 - 10.9
BB-Saddle Position: 76.8 - 78.8
Saddle-Handlebar: 54.9 - 55.5
Saddle Setback: 2.8 - 3.2
Look forward to any suggestions you have
Cheers
Will
Measurements
Inseam: 81.00
Trunk: 60.25
Forearm: 36.00
Arm: 65.00
Thigh: 55.00
Lower Leg: 55.00
The Eddy Fit (cm)
The French Fit (cm)
Cheers
Will
