DavidHenderson
Regular
Here are some key helpful points from my article on heat management for bicycling in the heat.
1. allow yourself some exposure to exercising in the heat (with common sense limitations) and allow time (see post for specifics) for adaptive response to occur (primarily plasma volume increases)
2. Hydrate properly and add electrolytes appropriately. Drinking large amounts of straight/standard water can make you very sick from electrolyte imbalances (Water intoxication is caused when sodium levels drop below 135 mmol/L when athletes consume large amounts of fluid that has not been treated with electrolytes).
3. keep your clothing wet (in particular your hair on your head (if bald, a dew rag can hold water), jersey and front panels of shorts. Water conducts (transfers) heat 25 times more than air; evaporation removes the heat that has been captured in the water. This is a really big deal for cooling. As an illustration: Tests done with canteens covered with water soaked fabric covering versus canteens with dry fabric covers produced a 42 Fahrenheit degree difference of interior water temperature (23.4 degrees Celsius difference). evaporative cooling effects on water containers. .
4. Cooling yourself by pre-wetting clothing and dumping water on your body during strenuous exercise helps slow dehydration and loss of electrolytes, because you will sweat a lesser amount.
5. Ice slurries can temporarily lower a person's core temperature and increase stay time in heat stress environment.
6. something, something, I forget what number six was.
http://myworldfromabicycle.blogspot.com/2010/05/heat-management-or-how-to-race-when-its.html
Stay wet my friends,
Regards,
David Henderson
Regards,
David Henderson
