Bike noise diagnosis idea
figbat
Former slippery scientist
I’ve had an idea for a way of tracing those annoying clicks, ticks and rubbing noises that are difficult to find. Perhaps it’s already a thing.
Apply a number of small accelerometers or vibration sensors in specific areas of the bike. Map them on an app. Connect the sensors to the app by Bluetooth or whatever.
Ride the bike. The app then analyses the noises and directs you to the source of the problem. Or at least gets you to reposition and refine the search.
Perhaps you could also define a baseline noise map for your bike and then it could help later diagnose a failing bottom bracket, or wheel bearings, or drivetrain or whatever.
Unlikely to be something you’d leave attached, used only for diagnosis and troubleshooting.
Does this exist? Is it possible? Is it worth it to help prevent “that’s definitely the bottom bracket” becoming “turns out it was the stem/seatpost/pedal/knees”?
wafter
Oxford
Sounds workable, although on cost / botheration grounds it appears unfeasible for your typical rider.
I suspect cheap mics would be fine for sensors, managing the wiring / interfaces and creating the app would be the hard part.
Years ago we did something very basic but effective at work. On the old CRT tvs customers often complained of high pitch whistles, some of which were intermittent. As there were a lot of coils/transformers that could possibly be the cause, we got a long bladed screwdriver and went to likely suspects. The tip was put on the component and the handle to the ear. The idea being that if said component was causing the issue, the sound would resonate up the screwdriver. It worked. Perhaps that was the cause of my hearing loss ?
Smartphones contain accelerometers so you 'just' need to strap your phone to your bike frame then interpret the data 🤔
