bikingdad90
I am breaking down my Kaffenback after writing the frame off in a freak minor accident at low speed (less than 10mph). I came a cropper on a white line and clipped the kerb and cracked the non drive side drop out which after a week of further riding resulted in the drop out snapping writing the frame off. There are enough parts here to build up from a frame. I will consider a bulk deal as it will sit around doing nothing as I got a replacement bike through the C2W scheme. A Boardman CX Comp. Not top of the line but good enough for a solid commuter to replace the Kaffenback.
Parts for sale:
Parts for sale:
- Norco 350mm seatpost 27.2mm diameter £7 posted.
- Shimano 5700 10 speed front mech. Braze on with band on adaptor £15 posted.
- Mini groupset £65 posted.
- Sram Apex Shifters 2x10 (right shifter is scuffed from works lock up and the fall but functions perfectly fine, left is lightly scratched).
- 11-32 cassette (on 1st chain. A little grubby. I can't find the spirits bottle to give it a clean).
- Sram Apex mech which takes up to 32t at the back
- Square Taper Cranks. The back says Sarco. They are 110bcd and 50/34. Again relatively new £20 posted.
- Redland cable actuated hydraulic dual piston disc brakes with mounts for 160mm rotors. They are designed for road levers. £25 posted. Less than 500 miles on the pads.
- Boardman bike saddle £10 posted.
- Tektro Lyra disc brakes with mounts for 160mm rotors. £10 the pair. Seen less than 6 weeks use and 300 miles at most.
- Tektro secondary brake levers. 31.8mm clamp £10 posted.
- Norco drop bars. I measure them as 44cm but maybe 42cm possibly £13 posted.
