We charge £12.50 per brake
Cheers for the feedback people, is it possible to diy bleed them then without a kit?
Yes.
If it's the same as a car/motorcycle then there will be a bleed nipple on the caliper. Fill the reservoir.
Open nipple, squeeze lever, close nipple, release lever. Repeat (While making sure the reservoir stays full)
Check lever pressure every so often. 10 minute job.
Could even buy a £2 syringe from ebay, and push the fluid through from the bottom. Don't even need to pump the lever then eitherOr better, stick a clear plastic pipe onto the nipple first , dipping under the surface.of a jam jar with some break fluid in it. More reliable, and maybe easier, for stopping air getting getting in and saves the opening and closing the nipple.thing - though that should work is more tricky (have done it too) to not get aid bleeding back in.
Could even buy a £2 syringe from ebay, and draw the fluid through from the bottom. Don't even need to pump the lever then either
Oops, meant to put push, not draw£2 ! are you made of money. Joking aside - not sure I quite follow how that method works. Sucking air out seems questionable
You fill the syringe with fluid, and push it in slowly from the bottom, forcing the air out of the top of the system.
