Blocked gas jet
PaulSB
Three of the rings on our gas cooker are working perfectly, the fourth will not light using either the ignition button or a naked flame. I'm sure no as is coming through the jet. When I removed the burner I found debris and water in the well surrounding the jet and feel it's likely either water, debris or both have got into the jet.
The jet looks to be removeable with a small spanner. Is this safe to do? I presume the gas flow is governed by the on/off dial and not the jet. If I try pushing a pin in to clear debris this might worsen things by pushing debris in further?
Any thoughts?
Could also stick a pin down the jet and make sure the burner parts are all clean.
classic33
Leg End Member
A pin is way too big for a gas jet. A piece of wire such as that from an electrical lead. One strand, rolled flat, should be small enough. And it'll be softer than the material the gas jet is made from.
I'd go no further than this, unless I had a spare jet to hand.
Is the area around the jet now clear of any debris? You can remove the jet, 6mm is a common size, but bear in mind you may have to seal it again when replacing it. Some are tapered to get around sealing them with anything.
OldShep
We’ve a propane hob. Every few years I take all the jets out and leave them soak in meths for a couple of hours. Shake them about a bit, blow through them and refit.
I feel that the propane gas leaves, over time, an oily residue. Don’t know whether natural gas does the same.
DRM
West Yorks
You're correct, Propane does have an oily black tar in it called heavy ends, usually it's worse in the cheap stuff, and some of the propane that was being sold about 2 years back was full of it,it was wrecking the LPG regulators on forklifts the length & breadth of Britain,costing companies thousands
tyred
Ireland
There is a tool you can get for this, a selection of very fine point tools on the end of a handle. My mum has one, "borrowed" from the kitchen she used to work in before retirement. The guy who serviced there appliances was always happy to give a few away.
Something like this https://ebay.us/m/xSwBwe
MontyVeda
I had a gas safety inspection done recently and the gas hob also has a blocked jet: Front right injector blocked - advise remove injector and clean... is what's written on the report, which suggests it's a potential DIY job rather than something that 'must' be done by a Gas Safe engineer. I'll be watching a dozen YT how-to videos before I'll feel confident I can tackle it myself.
PaulSB
PaulSB
Thank you. This and the video has given me confidence I can tackle the job myself as well. My next task is to find some of those little cleaner thingies.
