biggs682
- Northamptonshire
I suggest that the very fact that "the calipers have to be turned" and they "won't push in" means there is 'something' "stuck in the seatstay 'bridge' hole.
We can see the threaded nut inside the 'ole, no? See @biggs682 experience.
I don't think the OP will be able to extract this errant nut by 'unscrewing it' with an allen key per @fossyant : why would turning it have any extraction effect? Might be a useful 'loosen' though.
Get a bolt the same OD (?M5) and tpi as the one on the caliper, screw it in 'as far as' and 'tap' with a rubber mallet, supporting the seatstay securely.
It looks identical to the one I had issues with a while ago, It came out eventually but it was tough
