rb58
Enigma
- Bexley, Kent
The crank set on my fixed says it's suitable for a 103mm bottom bracket, with a JIS taper. This gives a chain line of 42mm. I've read Sheldon, so sort of understand what the chain line is and how to measure it. However, how important is it to get it spot on for a single speed/fixed?
Secondly, if I want to change the crank set for one that says it's suitable for a 107mm bottom bracket (or even a 110mm) bottom bracket, does this automatically mean I have to change the bottom bracket too? Or could I 'get away with it' and use the existing 103mm bottom bracket?
And, if I do need to change the bottom bracket, how can I tell which type I need? (Threads etc.)
Cheers
Cheers
