JeffBaines
- Manchester
Hi folks,
I'm a massive novice but I've been learning slowly over the past year how to look after my bike. Bare with me here, Imagine its your nan who's speaking so you understand where I've come from in terms of knowledge of bikes. So far I have:
- Changed the pedals
- Replaced the brake pads
- Replaced the rear cassette after being quoted almost double the DIY price
- Replaced the chain
- Had a go at adjusting the gears but failed miserably
- My drop bar/brake levers are bent massively (after I fell off quite spectacularly)
- My bottom bracket (inside the pedals) needs replacing as it whirrs at the same point in one full rotation
- Is it easy to fix the bent handlebars/levers?
- What bottom bracket will fit a Boardman CX team? The one on the spec doesn't appear to be in stock anywhere
