Bottom Bracket Size???
Funtboy
MajorMantra
Edinburgh
Measure the width of your bottom bracket shell (it will be 68 or 73mm) and then either measure the axle, or check the Shimano tech documents (on their website) for your chainset to make sure you get the right axle length.
Matthew
redjedi
Brentford
take out the bottom bracket. It should have the measurements on a sticker if it's still on there and readable.
If you can't read it take it to a LBS and ask for the same one, but then you may not get it for a fiver.
Funtboy
Funtboy
:smile:I had thought of that. I don't have the tools to get it out though. I was hoping to deduce the size, buy it on the net and then take it to the LBS to install it.
TheDoctor
Europe Endless
The TerrorVortex
Can you get the cranks off? If so, poke something through the axle (it's hollow) and use that to measure the axle length.
I will point out that the tools to get a sealed BB out will probably be cheaper than getting the LBS to do it for you - this will get the BB out and this will get the cranks off.
MajorMantra
Edinburgh
This is good advice. Just make sure you remove any washers before inserting the crank puller. Also, note that you need to own a socket spanner to use that puller.
As I said above, you may be able to deduce the correct axle length from the Shimano tech info.
Matthew
Funtboy
Funtboy
Great stuff. Many thanks...
Funtboy
Funtboy
Matthew
Thanks to you as well Matthew. I tried the shimano site but it was beyond my ken. Knowing that I had a 73mm octalink BB didn't seem to help me. I suspect you're not as stupid as me:sad:.
MajorMantra
Edinburgh
Actually I've just had a look at the site and the relevant bit is so badly organised that I couldn't find anything useful either. If you knew the exact model of your chainset you might be able to figure it out, but to be honest just measuring the thing is probably easier! :biggrin:
Matthew
Funtboy
Funtboy
Matthew
I have to get it out to measure it though and it's a toss up between buying the tools and giving it to the LBS.
Hmmmmmm.
MajorMantra
Edinburgh
Hmmmmmm.
You don't have to actually remove the BB to measure it if you use the method above (stick something though the hollow axle) but you do have to remove the cranks. Taking cranks off is easy though and if you're in doubt there are a slew of tutorials (biketutor etc.) online.
Matthew
