Bottom brackets
Johnymak
Ballymoney
If a square taper bb has allready been fitted to a frame
Will any square taper crank fit it
Thanks in advance
Merry Xmas and happy New year
Overconfidentii Vulgaris
No unfortunately. Cranks usually require a specific length of BB axle so that the chainrings line up correctly. You might be lucky enough that the BB matches your chainset but really you need to measure the axle length or take it out and see what's marked on the shell to be certain.
Ajax Bay
East Devon
Read this about ISO and JIS. Yours is most likely JIS.
https://www.sheldonbrown.com/bbtaper.html
Assuming a JIS square taper BB, a JIS square taper crankset will fit. The issue is whether the chainline will be correct (middle ring in line with middle sprocket).
Without disagreeing with the above posts, broadly if you're replacing a triple (or a double) with the same, you have a good chance that the crankset will fit and the chainline will be OK.
Chain lines: https://www.sheldonbrown.com/chainline.html
Axel length can vary. I switched from an old Deore LX to a newer Deore LX triple. It needed a shorter axel BB as the newer cranks were a lower profile.
Don't worry too much.
woodbutcher
S W France
I am (attempting) building up a Vitus 979 frame which already has a Stronglight BB fitted . It is my intention to fit a Shimano tricolour (double) crankset . Is it likely that l might have an issue with the axel length or am l panicking too early ? PS. l cant figure out how to get the S'light BB apart !
chriscross1966
Swindon
Stronglight bottom brackets tend to be from the cheaper end of the scale. What format is it and what is the bottom bracket size?... Shimano BB's are pretty good for the price and you shouldn't find it hard to match one to your new cranks.
woodbutcher
S W France
I will unscrew the Stronglight and take a photo later today with size etc. The Vitus B/B shell is threaded all the way through to match the S'light , so l don't know if that will be a problem if l swap to Shimano !
woodbutcher
S W France
This is it size 35 x 100 the axel moves smoothly and in any case l cant see how the thing comes to pieces , probably best left alone !
rogerzilla
Manufacturing tolerances vary a lot too. I have cranks and BBs from the same manufacturer (hence the taper *should* be matched) where the amount by which the crank slides onto the taper is very different. My TA track cranks slide so far onto the TA Axix BB that there is only about 2mm between the end of the axle and the seat for the crankbolt. My Shimano cranks are nothing like that, and nor are Sugino cranks on Shimano or Tange BBs (all JIS).
