Brake alignment?!? help
richard-clarke2
Hi,
My i had a fall or two from riding in the snow before christmas. From the first fall my front break pad was rubbing i tried to fix it and i was getting enough brake. I have been messing around with the brakes trying to fix both front and back now i have basically no brake because the brake aligns to the right on both front and back brake. How do i align the brake to the centre then i can tighten it properly. The is a good 3mm on the right side from the rims and and left side nearly touches
The bike is a trek 7.2 fx
thank you
Hi,
thank you
The bike tutor web site explains things quite well.
R
richard-clarke2
Thank you i think i have sorted it out as much as i can, the side screws were wrong. Also my brake pads need replaced especially the back. Thank you
