Maz
Spesh Allez: The brake blocks on the rear wheel were rubbing against the rim, so I widened the gap between them (loosened hex bolt, slackened cable and re-tightened bolt).
However, despite this, the brakes stay rubbing against the rims even when i release the brake lever - brake blocks are not returning to their 'released' position.
Maybe the brake spring on the back wheel is jammed up/rusty? Anyone got any other ideas what might be causing the problem?
Thanks.
really cr*p picture of rear brake attached...the spring I'm talking about is the one you can just about make out...the small double-turned wire in the middle of the pic.
Thanks.
