My current irrational fetish is to build up an old lugged steel frame with modern components. One of the potential pitfalls is the brake caliper mounting type; with earlier calipers having a stud that passes all the way through the fork / brake bridge in a close-fitting hole, to be secured with a traditional hex-nut at the rear.. while later / current calipers have a shorter stud that terminates inside the fork / bridge and is held on with a recessed, socket / hex nut that protrudes inside the frame / fork to some extent.
This means that the frames and forks are different for each mounting type; with the constant stud-diameter holes in earlier bikes requiring their rear / nut side drilling out to accomodate the larger OD of the recessed nut of the later calipers - something I'd very much like to avoid if possible..
In an effort to easily identify the brake mounting type on the frame and fork, are fixing types as simple to identify as single-pivot calipers having normal nuts and dual-pivot items using recessed nuts, or would that be too easy?
Ta
Ta
