Brake help
Saints.h
sweden
I am planning to buy new brakes specifically the Magura MT7 the current brakes I have now are Tektro Gemini. What I was wondering is do I need to change the actual rotors or can I just change the caliper
raleighnut
As long as the rotors aren't too worn they should be fine, I'd give them a good clean before using new pads on them though
Stompier
Unless someone who has tried that particular combination can answer, you won’t know until you fit them. There is a possibility that the calipers might interfere with the rotors. Or it might be fine.
