aravind123
Hi, can anyone recommend me a good quality brake pads brand for my road bike. Happy to spend a decent amount on them. thanks in advance.
yes improved performance. I shall research into getting better calipersAssuming the pads are to replace those pictured, are we to assume you're looking at replacement for improved performance rather than because they're worn out...?
If so you might want to consider replacing the calipers as a more viable long-term proposition. The Tekro brakes on my Boardman were pretty shocking tbh (can never fathom why, in our litigious society bike manufacturers nearly always cut costs on braking) so I replaced them with a pair of dual-pivot Shimano R5800 calipers on clearance; which are so much better in terms of both modulation and outright stopping power![]()
Cool - it appears that dual pivot stuff is where it starts to get good; so if you're looking at Shimano 105 and above. Also ensure that you pay attention to cable pull ratios as you really need to match the calipers to the shifters in this regard. I think Shimano brand all their stuff with the dual pivots and new pull ratios as "SLR-EV"yes improved performance. I shall research into getting better calipers
