Hi!
I've recently been having a problem with my single speed with the brakes not sitting properly. Both the front and back brakes won't return to the correct position after I've pulled the lever which can leave them rubbing on the side of the wheel until I re-adjust (by pulling them apart at which point they stay pulled apart until I nee to apply the brakes again).
I've had them loose, I've had them tight, I've changed the cable, changed the callipers, changed the tension on the cable, I've cut bits out of the black covering that goes over the cable because it was bending weird and putting pressure on the brakes, but I can't seem to get them to stay where I leave them. The rear brake is brand new and it still does it like my old one and I just can't figure out what it is so if anyone could help I would be very grateful!
