Brakes
Dogtrousers
Lefty tighty. Get it righty.
I hired a bike in France on hol a couple of weeks ago. It didn't take long to get used to the swapped brake levers. When starting off, and occasionally while moving., I'd give myself the usual pep talk: "Remember you're in France, remember what side of the road they drive", and I'd add "Remember which brake is which."
Ming the Merciless
There is no mercy
Inside my skull
From @Dogtrousers hospital bed
rogerzilla
Assuming the rear brake has no other problems like a flexy caliper, it can be quite powerful IF you hang right back off the saddle to get most of your weight onto it.
The fact that they are usually the other way around in Europe tells you the reason. It's not so much about which hand is usually stronger (which is the same in Europe of course), but about turning across traffic. The argument is that, when doing that, you should use the rear brake, hence left to rear in the UK.
You get some pretty zealous arguments on this, and people who can't see why anyone would do it differently. In reality, there has always been a minority, me included, who do prefer it the other way around. People talk about going over the bars from over-using the front brake, but a skilled rider shouldn't do that, and it's a bit inconsistent with modern arguments for disc brakes, which rather depend on the other types not being good enough for that risk to be real! It's important of course to remember only to brake in a straight line; front-wheel skids are much more serious, but much less likely unless you make that mistake.
I know that arguments can get zealous, and are never really resolved, because I once bought a reproduction copy of Cycling magazine from WWII days. They were arguing about it in the letters pages then, and in exactly the same terms as above.
I agree that predictability is important. If you're used to the brakes being one way around, try always to have them that way if you can. Work out what suits you, and stick to it.
si_c
Wirral
Ridden a few bikes with the reverse setup from the UK usual, not been an issue for me as it didn't take too long to get used to it.
I thihnk there is a good argument to be made (particularly with mechanical brakes) that the stronger hand should be the front brake though.
presta
An effective back brake can lock the wheel easily enough but a sliding wheel really will not stop the bike easily. One might say the laws of physics take precedence over the laws of the land
Easily is a subjective word.
BS EN ISO 4210-2 specifies two minimum braking forces, one for rear alone, and another front & rear together, and the figures for the rear alone are 61-66% of those for both.
Similar threads
