Breadmaker Recomendations
kingrollo
kingrollo
The recipe book that came with any machine I've had also listed the duration of each stage in the various program settings. Pick one that has a baking time nearest to your 35 minute target and test with that.
Out of interest, what's your ingredient list/quantities for your standard wholemeal loaf?
Wholemeal flour 450g
Sesame/linseed/sunflower/pumpkin seeds
Yogurt/water mix
1 tsp black treacle
Bicorbonate soda
glasgowcyclist
Charming but somewhat feckless
Scotland
Yogurt/water mix
1 tsp black treacle
Bicorbonate soda
I didn't realise that you were making soda bread. This changes things completely.
You're using bicarb as the raising agent, which doesn't require the long kneading or proving times which bread machines are programmed with. Unless you find a machine with a 'soda bread' or 'quick bake' setting, you'll be better off sticking to the conventional oven.
If you want to use the machine method then you'll need to consider switching to yeast. It takes longer and makes a completely different loaf.
kingrollo
kingrollo
Thank you.
I mean the existing recipe ticks the boxes for me - it terms of nominal salt bread. The rise isn't very large though means the slices are long and very small. But its quick , easy and doesn't require a whole load of ingredients.
Anyone got any links to an easy wholemeal bread that I can make with nominal salt
Dave7
Cheshire
Another +1 for Panasonic. I follow the basic suggested recipe but put only half the suggested salt in. The only failures were when I used old yeast ie I use packet yeast and I left it open for too long.
I to only baked wholemeal.
OldShep
As far as I am aware most of them will have wholemeal recipes. The salt is only there for flavour, I just use half a teaspoon of LoSalt in my loaves and they are fine.
Ours is a Panasonic - the most basic model.
The salt is also there to slowdown the action of the yeast.
Made my own bread for over 40 years. The last 20 years I’ve used a Panasonic. Now on my second one the first lasted over 15 years making 3-4 loaves / week.
annedonnelly
Girl from the North Country
Canonbie
Panasonic for me too. I did have another for a while - maybe Morphy Richards? - but the Panasonic is much better.
Thank you.
I think you can make any bread without salt if you choose to. I once went on a bread-making workshop at a local college. The guy had forgotten to bring any salt. We made the bread without. No problems with the rise or baking. Just that it tasted like it had no salt in it.
When I use my breadmaker I don't add the sugar. I don't think it needs it. And I probably put in a bit less salt than the recipe states
doughnut
If my 20 year old Panasonic ever broke (though there is no sign of it doing that), I would buy another one immediately. There is a great facebook group for the Panasonic with recipies and ideas.
