Broadband speeds
marinyork
Resting in suspended Animation
Logopolis
Have you run a trace route? What ping did a speed testing site say had you had? Have you had a look inside the cable modem and seen what the power levels are?
Yes, a laptop could certainly get lower speeds. You can easily check this by plugging it in direct via ethernet.
It's most likely either a local 'intermediate' capacity problem or power levels.
NormanD
Lunatic Asylum Escapee
[QUOTE 1616876, member: 45"]We're on Virgin broadband, which is usually consistently fast. It's been slow at times over the past few days, so I've just been doing some speed tests.
Tests are varying between 0.79Mb/s and 14, but averaging about 5. That seems really slow. Is it? Anyone suggest what's going on? Can it have something to do with our wifi or laptop, or is it likely to be outside of the house?[/quote]
I'm on the same service and it's been the same for me the last few days, so you're not alone, try switching off the router and restarting it again, it'll help improve the speed
gaz
Cycle Camera TV
South Croydon
Internet connections are often pooled by the service provider. This essential means at peak times your connection speed will drop. Usually between the hours of 7pm and 9pm it is most noticeable.
