Broken down tube shifters
grishaaa
Regular
i was in a day trip,and at last miles before getting home i came under thunder storm.then i have trouble while reassemble and cleaning with downe tube shifrers (Campagnolo record),when i tryed to release it,cable stop ring,which attached to down tube was just cut off((( probably because metal is pretty old.So i want to ask,is it possible somehow fix it like welding or another way to diy.right now i cant get new one,its at least one month of waiting delivery time(.i just dont want loose almost a half season on it...
im tryed to fix it by metal strap from hardware store,but it prevents switching shifters,so its did not work..
have any suggestions?
KneesUp
Options I can think of:
1) find a friend with a bike they don't use - borrow any old shifters off that.
2) buy a scrap bike and use the shifters off that. You could sell the other bits?
3) get someone to weld the two parts of the shifters onto that repair strap (jubilee clip)
As your gears aren't indexed any old shifters will do, and basic ones are quite cheap - they will keep you going until you can get a 'better' replacement.
Lonestar
I got mine off of ebay for the Audax.
Isn't there a way you can fit them onto the lugs on the frame.That's what I did.
TheDoctor
The TerrorVortex
SJS have band-on levers from £9.99. They probably have the band by itself, but there's a limit to how much Googling I can be bothered to do on a phone.
KneesUp
As the OP mentions a month delivery time, I am guessing he or she is somewhere where it will take a month to get new ones delivered - and the question is how to get the gears working during the month of waiting.
grishaaa
grishaaa
Regular
i found almost a same shifters on ebay,they are perfect,indeed,but it will delivered around a month,during which i have no bike,so its not cool,i beleve there is should another ways,how to fix it permanently.
grishaaa
grishaaa
Regular
every one around ride on fixgear or single speed, so its like exotic bike part in my area.i hope welding can be resolve this problem.
Lonestar
Another option is just use it as a one gear bike.(I've done that before).Hopefully there aren't any big hills or whatnot but where is n+1?
Tim Hall
Crawley
Whereabouts in the world are you?
Ajax Bay
East Devon
I have the same generation Campagnolo Record levers.
Pending arrival of replacement band, I suggest that you use a hose clip like the one pictured, but wider. Cut two holes the correct distance apart which will slot over the two raised areas of the Campagnolo band and secure/tighten the hose clip underneath the down tube, where the fastening will not foul the levers. This may not work (because the worm grip thread in the stainless steel makes it too weak) but it might, and get you riding again.
