SavageHoutkop
- South Manchester-ish
The nearest LBS I trust to do a good job is in Oxford.
Warlands? They were the ones that opened up my hub.
1625771 said:My understanding is that the hub dimensions are fine but the 36 spoke drilling is not because it makes getting a pump on the valve very tight.
You could but spoke measurment would be a bit hit and miss. It might mean some spokes needing to be filed down a little and others showing threads.Presumably you could still build a wheel with a 28 hole rim and a 36 hole hub.
Forgive me for being blunt but it looks like you should take your wheel and hub to some one who knows what they are doing .................... Talking about getting alternative hubs, gear systems might be a waste of money and time when the solution might be a lot simpler and cost effective by getting some one to look at your existing one and repairing/servicing it for you. Reading to Oxford is not so far.
