Fastpedaller
- Norfolk
I've had a bit of difficulty getting the schrader valves on the inner tubes of my 2007 Brompton (only had it a couple of years!). The valve is tight between the rim sides and 'drags' the edge of the rim tape into the hole, damaging the rim tape in the process. I'm reluctant to 'trim' any material away from the sides of the hole in the rim tape, because that's the place it's most likely to break. On my second pair of rim tapes now - the originals were very rigid plastic, the rear one cut into the tube, so I've today replaced with softer plastic ones.
Has anyone else had a similar problem? I'm thinking I may be able to 'ease' the inner wall of the alloy rim away a little, as that's where it is very tight with the valve stem.
