robgul
Being a Brompton virgin ... with a neglected machine to refurbish I have a few questions please.
The machine I have is, I think, a T type c 2003/4 - had a 3-speed hub and 2-speed deraiilleur - AFAIK the chainset is original. The previous owner in his wisdom removed the derailleur but didn't twig that with "modern vertical dropouts" it would need a chain tensioner!
Technical info on the net for Bromptons is pretty sparse, so:
1 If I get a chain tensioner for a 3 speed (i.e. one cog at the back and dispense with the 3 extra gears) will it work, making it a 3 instead of 6 speed.
2 What sort of gear ratios will I get - depending on which cog I use? (ideally expressed in gear inches 'cos I understand them) - my use is likely to be on pretty much flat roads
3 There are 2 cogs on the hub at the moment - it looks like I can remove one - is there a shim of some sort to get the chain-line correct?
4 How many links do I need in the chain, and I assume a magic link will be OK
5 The cables (inner and outer) are pretty poor - I assume other than the gear inner trigger cable for the hub that the outers are standard issue brake or gear?
6 I'd like to separate the rear triangle to either get it powder coated or paint it - the two Allen bolts are rock solid - I assume if I got them out it's all pretty straightforward to put back? [I may leave this for now - or put the frame on its side and keep dosing with PlusGas to see if one of the bolts moves]
For the most part the rest of it seems OK, just very dirty - the RH pedal was rubbish and I've ordered a new one, together with the clip on the headtube that holds it folded (the spring was missing) - and when I want something else from Spa to justify the postage I'll buy one of their "non-fold" clips for £4 instead of the £26 Brompton wants for the retro fit (larger seat clamp bolt) trigger clip gadget.
All answers and tips gratefully received!
Thanks
Rob
Thanks
Rob
