Buying new wheels
Discussion in 'Beginners' started by Moonchester, 1 Jun 2008.
  1. Moonchester
    Moonchester New Member
    If I want to buy a new pair of wheels, what else do I need to buy to enable me to quickly change between two sets - i.e. to remove one wheel with tyres, slot in a new wheel with tyres and pedal off?
    New wheels seem to come without cassettes so I think I need one of those (am I right to assume that if I buy the same cassette as on my existing wheels, I don't need to adjust the gears?) but what else do I need?
  2. ASC1951
    ASC1951 Guru
    Yorkshire
    No, that's pretty much it. You'll just have to swap the skewers over, unless you are getting a new set of those as well.
  3. Spot on. If you take out a wheel look at it every thing you see you will need.
  4. Disgruntled Goat
    Disgruntled Goat New Member
    Swapping a cassette over onto another wheel is fairly quick with the corrected tools - can be a bit messy though.
    Cassette on each wheel even easier
  5. Fab Foodie
    Fab Foodie hanging-on in quiet desperation ...
    Agreed, but cassettes need to have a similar amount of wear, otherwise you may need to swap chains as well because an old chain on a new sprocket will not work.
  6. OP
    Moonchester
    Cheers all. I'll think about getting a new set of skewers as well.
  7. OP
    Moonchester
    Why's that?
  8. walker
    walker New Member
    Bromley, Kent
    they wear at a similar rate, so the stretch on the chain will be the same length as the wear on the teeth on the cassette. a new chain slips some times
    Dismiss Notice
