cyberknight
- Land of confusion
Just been setting up the brakes on my old boardman and i have problems.
The QR lever has play in it , although i have tightened it up it still wobbles .It does not operate correctly when i turn it to release the cable tension so i cant get the wheel out unless i undo the bolt holding the cable and when you turn it back the bolt head sits turned in towards the frame more than it should .
These brakes are tektro 730s ( i think) and are original on the bike from 2011 , and the cables are original but only ridden in good conditions although they do have a large flat spot where they have been clamped .
