Or simply fit the larger sprocket then see if there is enough chain to go big big front and back. If there is then you are ok. However there maybe far too much chain in the opposite direction i.e. small small meaning the chain is flopping around as the deraillieur is not under any tension as the chain is too long. I am sure Graeme_FK van give a more in depth analysis but these are just my lay observations. If you know anything about bikes you wouldn't knowingly select these gear combinations anyway as you are in effect twisting your chain right across the width of the cassette to the outer or inner front chain ring which is not good and if done repeatedly will lead to premature wear of both chain, sprocket and chain ring. Also as Graeme_FK states SHOULD the chain or deraillieur become jammed or break or go into the spokes because it is over stretched or zero tension because there is insufficient or too many links in the chain then the consequences don't bear thinking about as the damage could be considerable as well as the risk of injury to yourself if you come off.
But to answer the OP my gut feeling is no, as the size range in sprockets 11 min and 29 max is too great, but suck it and see. Why not go 12-25 or 13-26 which are well within safe use limits? What size are the rings of your front chain set? It is unlikely you would spin out on a 53 or 52 front ring on a 12 rear sprocket or even 13 unless you can cycle faster than 40 mph on the flat
! What's the size of the inner chain ring - 39 or 42? If there is a wide range in sprocket size in your rear cassette you have much larger jumps between gears. Perhaps the better approach would be to look at what size front chain rings you have and maybe make some changes here?
Also you should consider whether your rear deraillieur has a suitable cage length and whether you are exceeding the spec of this in what you are trying to do.
Currently I use an 11-21 9spd rear cassette with a 52/42/30 triple front with 700c wheels and I seldom get off the middle 42 chain ring as it is pretty flat although some gentle hills occasionally carrying two heavy rear panniers which slows me down so I am on the lowest 21 sprocket. I did use a 12-25 but found the 25 sprocket too low and I wanted fewer gaps in the mid range of the cassette. I seldom get higher than the 13 sprocket though at the moment, seldom use the 12 and never use the 11. The latter's use is to stop the chain coming off
. I suppose if I were going down a mountain col then maybe I'd get onto the 11 sprocket and the 52 front ring, but the brake blocks would probably melt trying to stop the bike I'd being going that fast …………….
For hills I just go down onto the 30 front ring and of course I can put the 12-25 cassette back on should I feel the need.
The Sheldon Brown gear calculator is a great help.
