Campagnol - Bad shifting on second hand Wilier
Danielaaron94
SO. I have a Wilier Gran Turismo (2010) that I bought second hand from a Wilier dealer last year. It worked flawlessly at that time.
I started having some shifting issues recently, none horrible or unrideable. the most noticeable issue was that it was sticking in 3/4/5 when trying to shift up. So I decided to swap out the chain with a new Campagnolo 10 speed, waxed. Chain swap went fine, matched with old chain and measure for fit.
Now, I cannot get the rear derailleur adjusted well at all. It shifts a lot worse than before, either sticking in gears or skipping over. I can get it to shift really well up and bad down, or really well down and bad up, but there does not seem to be a middle ground.
I am no bike mechanic, and unfortunately do not live near one. I did some research and ran through the rear derailleur install a few times and just cant get it to shift well.
I am starting to think that maybe its just a little worn out given its age? Can I install a new derailleur on this dated bike? Thanks
Loch side.
I doubt you will relturn to read this but one lives in hope.
Firstly, worn out gears do not affect shifting. Tooth profile has NOTHING to do with lateral derailere movement. Niks, nada, ziltch.
Secondly, shifting issues are always a function of:
1) High cable friction (old crappy cables)
2) Poor adjustment regime.
3) bent derailer hanger.
The above is subject to all parts fitted being compatible of cours.e
An experienced mechanic will look at all theses factors.
No amount of guessing from fellow members will deliver an aha moment. Stick to the basics.
  • Like
Reactions: C R
Pblakeney
First thing I'd be looking at is replacing the cable. For two reasons.
1. That is usually the culprit. The area inside the hood gets frayed and affects shifting. Eventually snapping, then it becomes a bigger issue to remove.
2. They are cheap, if you shop around.
  • Like
Reactions: C R
But is it adjusted correctly (with the barrel adjuster on the rear derailleur), so that each shift lines the derailleur up correctly with one of the ten sprockets? Easiest way is to look in a middle gear, and make sure that the chain is going down exactly vertically from sprocket to top derailleur pulley. I can't tell from your original post whether or not you know how to do this although, if you've changed a chain, you probably would know?
