Campagnolo Record Brake Calipers (c 1994)
For sale - Record brake calipers.
Dual pivot with bearings front and rear.
All original bits intact apart from one washer missing.
Faults - a couple of small scrapes on both which have turned black with age - will polish out if you are careful.
The replaceable brake pads are very worn and will need replacing.
Have cleaned and serviced these apart from the bearings located on the central bolt - the hex key needed is a very unusual measurement so I have just oiled this area.
Bit of rust on the nuts as usual -otherwise nice and clean.
£15 posted.
(pics to follow)
