Hi All,
has anyone replaced the centre brake pivot bolt on Campag Skelton brakes? I need to add a longer bolt as the front caliper bolt doesn't fit old school forks. I was thinking of using the Jtek Tektro 70mm bolt from SJS cycles but I can't determine if the head will fit the recess nor if the threads are the same. It would be a bit of a gamble, or I chicken out and by another set of calipers.
Here is the replacement bolt. Any advice is greatly received.
http://www.sjscycles.co.uk/jtek-tek...rake-bolt-cr-mo-for-nut-conversion-prod24266/
