can bontrager wheels fit any freehub?
  • no
    Votes: 1 100.0%
  • yes
    Votes: 0 0.0%
  • Total voters
    1
tanjinghung
I have a bontrager wheels for 10 speed but i have upgraded to 11 speed and finding a freehub to change ..but i don't know what freehub can i use.
cyberknight
Are you sure your wheels will take an 11 speed freehub ?
cyberknight
I dun get wat you mean?
To fit an 11 speed free hub which is longer the wheel has to be dished tighter on the drive side with a narrower axle , some newer wheelsets and mavic wheels are compatible with 11 speed cassettes and are normally marked 10/11 speed and come with a spacer to use 10 speed , older wheelsets are not compatible and you might need to replace the wheel .
If in doubt ask the LBS or a trek dealership
winjim
Campagnolo 10 and 11sp are exactly the same width and can just be swapped straight over.
