The misses' laptop screen has gone very dark. And I have tried turning up the brightness. Laptop itself works fine with an external monitor.
So I'm guessing it's either a screen or an inverter problem, hopefully the latter because that's cheaper to fix. A screen is around €150, inverter €20.
Anyone any ideas on how to test which is at fault though? Or which is the most likely... gut instinct tells me to take a punt on an inverter.
Incidentally, we took it into the local computer shop and asked for a fault diagnosis. Motherboards gone, they said, it's beyond economic repair... but we'll sell you another laptop and not charge you for the fault diagnosis. Thanks, I said, but I thought the motherboard/video card was ok if I could get an external monitor to work. Ah yes, he says, cascading problem... the motherboard was probably okay before but it's broken now. Hmmm, I say, how much for the fault diagnosis? Took the laptop back and came home. Yep, it still works with an external monitor.
See
